1 - 9 of 9 Posts
I am having battery troubles. Unfortunately, I mainly go on short distance rides that rarely get to acceptable speeds and distances for battery recharge (big city with traffic). I have seen Shorai recommended and believe Shorai LFX18A1-BS12 would be the appropriate battery for a streetfighter 848. Can anyone confirm this and/or offer their experience with this battery? Is removal of my dead battery simple?
Battery is a YT12B-BS which cross references to Shorai LFX18A1-BS12 and is listed for 848 SF so you should be good to go with that one.
Removal is dead simple
1. Pop off the passenger pillion/cover using your ignition key
2. Remove the 2 screws closest to the front of the motorcycle using the hex key provided
You will then have access to the battery. Remove the negative (black) terminal first.
If you're inadequately charging your battery due to short distance travel, then you should seriously consider a way of connecting it to a tender when not in use.
Your battery needs the most juice when starting and you'll start eating away at the same charged cells if you're rarely ever able to charge all the cells fully which will prematurely decrease the life of the battery.
Also, just in case you didn't already know, you'll need a specific charger for that type of battery.
To add onto what azt108 said, you may also want to keep in mind that Shorai batteries are very sensitive to going flat. If they are fully discharged, it can cause permanent damage. This happened to me with my old 1098: PO had installed a Shorai, and it went flat during my first winter of storage, which ended up ruining the battery. Shorai was good about partially warrantying it, but it still cost me some money.
They're good batteries, and have their advantages, but the battery tender is definitely a necessity if the bike is going to sit for more than a couple weeks at a time, or if you're doing short trips as azt noted.
Hi,
Just purchased the YT12B-BS to replace the old Battery that was in the bike YTZ10S-BS and there is a huge difference in dimensions. The YT12B-Bs seems to fit ok, it is way slimmer to loose in the compartment it goes in. Do you guys think I still put the YT12B-BS in and use it? For reference here is the picture, the YTZ10S is a snug fit in the compartment in the bike (SF848). A fast reply would be appreciated !! :). regards
1001818
I'm guessing your bike must have been modified in some way to accept that battery. The YT12 is a pretty tight fit in the standard battery tray, I'm not sure even how that other one managed to fit.
I would agree, YT12B-BS is the factory installed battery, anything else in there something was modified to make it fit.
1 - 9 of 9 Posts
