I searched around a found some mildly related threads but nothing with the same issue.
Bike ran when I got it in Sept. It's since been completely dismantled and rebuilt.
Finally got it back together enough to try and get it running. Turn the key on and right switch to run. Fuel pump primes, and I hit the starter switch and it fires right up. It start and runs and I notice I've got no tach. Tach has power for lights, and oil light, but doesn't move.
Turn right switch to off, and key off. Double check wiring at tach, seems ok. So I turn the key back on, and the right switch to run and no fuel pump. The relay for the fuel pump just keeps clicking over and over and over again.
So I shut everything off again, and pull the relay for a few seconds. I install it back on the bike, turk on the key and run switch, and the pump primes again. Hit the start switch, and she fires right up.
I shut it off again, swap the two relays and try again. It fires right up, but after I shut it down and try again same thing. Relay for pump just keeps clicking away.
The ECU has been sitting in a drawer of my tool box for over 6 months. I haven't popped the plug off to look inside and see if there's any crap on the board.
I am thinking of asking my friend or coworker to borrow the ECU from one of their 748's to rule that out.
Anyway....any thoughts on why it would do this? Seems bizarre that the bike will only start if I pull the relay and hook it back up. Thanks for the help.
