I rode the bike early early in the year, and when I parked it I thought I'd be riding it again soon, then life interrupted. I came back to it the other day thinking the battery would be dead, but no, it fired right up. It was running fine, then about 30 seconds in gasoline started flowing (flowing=pouring) on to the ground. Turn off bike. Remove fairings. Search around with no luck. Restart and see gasoline flowing from what looks like a plug in the airbox. Turn off bike.
Pull tank up and find a nice, comfy, cozy mouse bed of some kind of fluffy cottony material in the battery/coil area. Pull all fluffy stuff out and inspect wires. Fortunately just one set of wires has some chewing of the woven outer insulator. Ponder and puzzle and decide that mouse probably didn't make a similar bed inside the airbox, but ran out of time to investigate. As you can see from the pictures, the air filter is lock-wired on, so I don't know what I'll find in there, but it seems like if there was fluffy stuff clogging things up then the bike wouldn't run, or would run poorly, but it doesn't.
Bike has 944 kit, but stock carbs and unbranded CF end cans. Thoughts and suggestions on what would cause to fuel flow like the line from the fuel pump was removed and stuffed in the air box, but still have the bike run fine (at least for a minute or so) appreciated.
