1 - 17 of 17 Posts
Hi guys,
Today while riding I started hearing this odd metal clanking noise from the right side of the bike. It’s a 2019 950S with less than 300 miles.
Have anyone experienced something similar? Any suggestions? Or this is just the bike’s regular noise that I’m not used to?
Thanks!
It's hard to tell from the video over a computer but that may be pre-detonation; sometimes sounds like a metallic "pinging" but I'd expect to hear it from both sides of the motor not predominantly the right side; what fuel are you using? That does not sound like a regular engine sound to me so I recommend taking it to a dealer ASAP. How does the motor feel when riding? Does the noise go away as the engine revs are increased? As Ricko notes, the clutch is on the right side but it should not be making this sound. I don't want to be an alarmist but a after a quick Google search, this is not a unique problem. The following is from a Supersport forum; different bike but similar problem, metallic sound:
"Well, after several weeks without a motorcycle I already have a diagnosis of the "defective distribution gear" workshop. Apparently the defect of the cemented of the teeth of the same has caused that it is marked, the noise is generated and through the axis of the second pinion, the large one, the noise is transmitted to the other side of the engine, to the distribution pulleys, or that at least, that's what they told me. It seems like a small thing but if left, engine in the trash in no time. I hope that the 2800km that has been rolling like this, it has not affected anything else, but come on, to get to that element, it has been necessary to disassemble the entire left crankcase, water pump, antifreeze, alternator, alternator rotor, starter clutch, gear Starter, gear harpoon, gear gear sensor, crankshaft position sensors, oil, gaskets, ... to see how all this is put back as it was on a motorcycle that has just finished shooting.
To all those who have said that the noise was normal "character ducati" and such and such ... it also seems that it is not an isolated case, I have been told that now that they have located the problem they have fixed on other engines also what They do, it is possible that they call for review in the coming months, because a gear is not manufactured one by one, but batches of hundreds. All this is aware of the factory in Bologna, which is the one that marked the guidelines of what was being dismantled, as I have been told.
The truth is that despite being disappointed with the quality control of the brand, the official dealership in the area is doing it beautifully: wink:, something that doesn't surprise me because I had received very good references and know that you are trying your motorcycle as if it were yours, it calms down a lot and for that part I am very happy. I do not even want to imagine having half a disassembled motorcycle, with just the filming done, in an arrogant place without explaining anything, for that part I have been very lucky.
I will be telling you how the thing is when it is finished that the replacement parts of Italy are still to come and these things with the technology that is there today should not happen. Hopefully it looks good to be the first ducati I have ... "
If you pull the clutch in what happen to the sound?
Yes, that sound is on N, once I pull the clutch it doesn't change. I tried again this morning and the noise is louder when the engine is hot. When I turned on from the overnight I wasn't able to hear it so vividly.
Mine doesn't sound like that. Do you have enough oil?
Yes, in the high side of the normal limits.
You can't diagnosis this from a smart phone mic, it will amplify any noise with the slightest change in how you hold it. Impossible to diagnosis on a forum. Could be a total disaster or could be perfectly normal. You need a mechanic to actually listen to it.
Take it to a dealer and have them put it in the system so that even if they state it is normal you have record of the attempt later on if it does turn out to be something catastrophic. While in warranty do not be afraid to use it as this is your only benefit to buying a new bike in the first place.
Ducati and many dealers would be happy to have a issue show up after warranty is up so they have little to no cost dont help them out get it checked.
Hello.
I have 2012 model multistrada 1200s at 43.000 km
And last week it makes the exactly same sound.
Like metal thing hitting something.
Although I have still have time to make desmo service to solve the sound the dealer made tgw desmo service we changed the all belts and all tensioners and rollers even the 3 rollers in the altenetor side.
But the noise is still there.one of the service guy says its not so important sound but for me its not.Please share with us if you fix the problem?
Discussion Starter #10
Took it to the dealer, they all listened to it, rode, and unanimously told it was normal. Even turned some other Multis on (1260’s and 950’s) to compare the noises.
This was about 1000 miles ago, first service was done 500 miles ago, and it’s running normally (although still has the clinkling noise).
I am thinking that its not normal because in my bike It was not clinking before. And your bike is also brand new. If this is normal why other bike dont have that sound.I am getting crazy abouth this issue
Any progress abouth the noise ?
Discussion Starter #13
Still there, although since I no longer pay attention to it it seems it's reduced. Next ride I'll pay attention to it and let you know.
In mine situation we open the all engine and it seems that
Crank main bearings doing that sound.
We will replace the crank bearings
Discussion Starter #16
This past weekend I paid attention to it.... still there, although it seems to have slightly reduced
ın my situation we tought it was the crank bearings but it wasnt. We opened the all engine with good mechanicker. He says that the sound is from the upper side of the engine.
He will set the clearence of the valves and he will trained the valves by special tool I dont know. And he will change the upper side gasket.even though the crank bearings have some scratchs on them. The metalic noise is not coming from them. Its all abouth the slack of the valve adjustments on the upper side he says. And he said thay if you ignore the sound after 100 kms your engine would be harmed much much worse.
So I am glad to do the engine adjustment before I got much trouble. But in my side my bike is 44.000 kms . But you guys have a just brand new bike. So I am not sure that the problem is same. But one thing I know is dont ignore the noise. Because other bikes dont have metallic noise on them.
1 - 17 of 17 Posts
