Well i have the 998 pipes on, removed the straight pipe and fitted some perforated pipe to it instead, fitted up sounds allot better than it did with stock system and with the old straight through 998 pipes.
My question again do i go dp map or stick with standard map? Seems to be running ok with the standard map though.
Thanks
Thanks
