steering neck bearing part numbers
3165 Views 7 Replies 3 Participants Last post by  JDuc
I know I could go through speedymoto, but they are out of stock.
Does anyone know the bearing part number? (for lack of the correct term, sorry)
NOT the ducati part number, but rather the bearing numbers...
apparently the supersports are the only duc that comes with a tapered bearing (according to Christian Hansen at SpeedyMoto).
Would the regular bearing and the tapered bearing be the same bearing number just with the tapered bearing being specified at some point in the part number?
We have a Purvis Bearing store around the corner and I'm pretty sure I could walk out with the two bearings, while I'd probably have to wait 3 weeks if I were to order them from the dealership, not to mention the probable price difference.
If I need to clarify anything, just say so. I'd appreciate any info anyone could provide!
1 - 8 of 8 Posts
· Registered
Geez, I just had mine in my hand yesterday here at work. [I was cleaning them...the gear shop next door has an ultrasonic parts washer] Now they are sitting home on my bench, waiting for me to re-grease them.
I'll have to look at one for the bearing number tonight, if you can wait that long. all I can remember right now, is they are SKF. Let me know.
The tapered roller bearing #'s will not be anything like a std. roller bearing #, it falls into a completely different catagory.
If your bearings are indeed shot, I would look closely at the races.
If you buy them from ducati, I believe you have to buy the set [bearing and race]
· Registered
if it's not the bearing/race then I've got some serious issues somewhere else in the neck...lol
while in arkansas for 2200 miles, the head bolt came loose. I had just installed the cycle cat triple tree and apparently didn't ride it enough after that and before the trip to let it set...I rode it and tightened it after a while, but it came loose again. So, for 2200 miles, every time I would stop or shift my weight I was tweaking those bearings. That and the previous owner didn't keep the bike in a garage...I've been noticing some problems, but nothing that I couldn't write off to just myself being over sensitive.
Now, after the long hard rain I rode home from work in the other day, I'm noticing some real issues. Grinding feel and sound after the bike has sat overnight or all day in the parking lot when I first get on it. Occasionally, I'll hit a snag, but nothing that serious....kind like hitting a small rock in the road, I have to use a little more force to turn.
I will want to go ahead and replace the races while I'm in there, no point to getting it all torn apart and not doing that.
how much should this part cost from a dealership?
thanks for the info about the part #s being different, wasn't sure on that one.
· Registered
I used to use powersportpro's partsfiche for pricing [but I don't buy anything from them, as they are complete idiots]...but since ducati closed their US warehouse, the prices seem to have gone up.
powersports has them listed at $40 bucks per....but I'd be willing to bet it's closer to $50. I would check with your local dealer. Check to make sure the races are included, I couldn't find a separate part# for them.
· Registered
I found the replacements at a bearing place but they cost just as much as Ducati got for them. (I got mine for about $50) I had talked to all-balls about them but they did not have them yet. I need to get those guys in my line up because I think the pivot and steering bearings are a good match to what we do.I would love to get an old bad set from someone to try to get the right match so we could offer those. The SS bikes eat them because they have no seals and the factory saves on grease!
When you install them, use a lower viscosity grease, not wheel bearing grease as it will act like a steering damper.
· Registered
Discussion Starter · #6 ·
Lower Viscosity grease like....anything specific?
· Registered
Jan
F.w.i.w......
the #'s etched on the bearing are: SKF 639174 GERMANY-S W25 T
I went to a few bearing websites [including SKF], and coundn't get a match on the part #'s
personally, I'd get them from the dealer. you could spend more time than it's worth hunting for them.
· Registered
Discussion Starter · #8 ·
ordered them from the dealer yesterday actually...
only thing that concerns me is that they didn't show any races...just washers and the bearing. I'm wondering if the 'washers' are the races....or if they are something seperate.
OR, more probable, the bearings and races are the same part #, come as a package deal...
hope so
1 - 8 of 8 Posts
