Hyperpro mounting
Hi CM99,
I have a Hyperpro on my 01 900 which attaches to the fork leg and the frame - see attachments. The difference for our models is that there are no mounting points to really suit the 99X dampers. You need mounting points quite close to each other - the frame (fixed) and the forks/triple clamp (movable).
Just had a quick look at mine because all the fairings are off and there does not appear to be these two fixing points, even below the bottom triple clamp.
As you will see from the pics, the shaft has to be very long to accommodate the rotation of the forks fully from left to right. Richard
