I changed my sprockets out a few weeks ago and haven't been able to test ride it due to my father passing away. I was finally able to take it out for a ride today and the clutch started slipping real bad. I knew it couldn't have anything to do with the sprockets so I thought it was odd. I limped her back home and checked the fluid. All is good. So I took the clutch apart and found that the steel plate at the bottom was stuck behind the drum. I put her back together and all is fine again. I'm just curious as to why this happened. Any ideas?
