1 - 3 of 3 Posts
Had the fuel tank off for deep cleaning, reconnecting the right-side "In" connection was iffy but got to seal. Bike starts, runs rough and not for more than a few moments. Found damaged black o-ring in connector. Could that create this issue? Nothing else was disturbed.
Replace it and find out ? Obviously fuel related, most likely not coincidence to what you just did. Sorry , that’s all I got, since I don’t know what model we are discussing.
You must retrace your steps and check everything over, including replacing the 'o' rings. I find that the fittings go back in more easily if I add a smear of grease to the 'o' rings.
1 - 3 of 3 Posts
