Starting Problem 04 999 6100 miles
658 3
Strange problem, when starting the bike I can let go the switch and the starter still runs till the bike starts. I changed the switch but that did not fix the problem. Now I notice something new, if it does not start on the first crank and the switch is pressed again nothing happens until the key is turned off and on again, any ideas.
on 999/749, the button should be pressed and released to start. You don't need to keep holding it; the starter will crank until the bike fires up.
As for the issue with having to turn off and back on, check battery voltage, fuses, wires to and from battery.
... Now I notice something new, if it does not start on the first crank and the switch is pressed again nothing happens until the key is turned off and on again, any ideas.
This is by design. if you turn on the key, there is a 10second window for you to hit the switch. after that you have to turn the key off and on again. This should be in your user manual
