The last two times I've been out on the ST3 I've found it won't start when it is in gear. It will be in first, I pull the clutch in and nothing. I've checked, the sidestand is up and the kill switch is off. Once I go back to neutral it is fine. Seems like something went awry, but I'm not sure what. Any thoughts?
Thanks
Joe
Super Moderator
My clutch switch went. Did the same thing you're describing.
The switch split opened and dumped its contents. You can fabricate a replacement or you can do what I did...bit the bullet and bought an OEM replacement (about $70). I wasn't feeling very creative. Next time, I'm going to try to fabricate!
Thanks, sounds like the likley culprit in this.
Joe
