1 - 3 of 3 Posts
My st2 will not start due to reverse polarity upon battery install.The 40 amp fuse replaced,all other fuses ok I get display,lights and all, no fuel pump run. starter will not work. Anyone have ideas on trouble shooting?
Starter relay from under the seat?! Switch it with the fan relay and see what happens... (mine was toast)
Use the SEARCH function in here. Backwards polarity battery has been in here MANY times. usually, just the 40A fuse "protects" the RR, as yours had blown. It might take out the RR also.... YMMV
Some have toasted the ECU, IIRC...
1 - 3 of 3 Posts
