Well a few things come to mind. First being, clutch plates out of order are a no no. They come out one way and go back in the same way. I don't know if that's your problem....Next..Lithium grease on your plates? I've never heard of this! The grease may cause your plates to actually bind up....Did you line up the mark on your new pressure plate with the mark on the stud? If that doesn't make sense you probably didn't..... Since your clutch lever has similar clutch pull before you tore things apart it sounds like you spaced the clutch springs correctly...
Sent from my iPhone using Motorcycle.com Free App
