O.K. Here is a weird one. I was doing a little Horn work on my ST4s last week. I installed a set of Electronic Air horns MAXI Sound from http://www.wolo-mfg.com/elec.htm . It was not easy but got it done. I think in all my removing of panels and new wiring I must of bumped or disturbed something. Because when I went to start it the next day I turned the ignition to on and the bike was trying to fire but would not catch and start up. I had not hit the starter button.... The clutch was spinning and thumping and rattling like a dry clutch does but no fire. It was weird. Then it finally caught after I hit start button and fired right up. Got to work and put bike on center stand and turned key to off position and motor turned off but it was still trying to turnover just not fire. I actually had the key in my hand the bike was still trying to turnover. Put key in and turned to on position hit starter and the bike fired right up. This went on for about 15 minutes of turning key off and pulling it out of ignition. It somehow just stopped and I was able to get the bike turned off and starter to stop trying to turn bike over.
I have never had this problem and it has not come back. Any suggestions??
