Not my finest work by any means, and I am not sure the location is going to be permanent (but probably will be). It is a nice improvement, however, as in it actually works and the MOSFET VRRs are a big improvement over our old style OEM regulators. I have had one in the 916 for most of this season. Steady, clean voltage all the time, even with the single phase generator found in that bike, and much less heat generation. My ST's OEM regulator was dying. Diodes still read good but the regulated voltage level was dropping. I noticed it at idle with the tach dropping to zero and the battery was on the weak side at start up. Stator checked good for both cold check and running.
I am a cheap bastard and hate to pay full price for anything I can get that is serviceable for less... I did the same this time as I did for the 916. Yes, I know new kits are available for reasonable money, BUT you can buy used MOSFET regulators on eBay for less than $40.00 and the plug kit is around $19.00 from here: Home
The VRR I sourced is a FHO12AA. Rated at 50A. They are found in several Yamaha models, mine is out of a 2007ish R1. More info here: http://www.ducati.ms/forums/80-hall-wisdom/94947-upgrade-fix-no-more-charging-regulator-rectifier-problems-8.html
So for about $60.00 I had my upgrade. I have wire and such already on hand, so I didn't count that expense.
I didn't do my homework and was disappointed to find the new regulator does not fit in the same location as the OEM. It is smaller and lighter, but just a bit thicker and does not slide in far enough to the air intake. I considered making it thinner by filing the fins down, but instead relocated it to a spot just above the battery. Not sure this spot is available on anything but the ST4s, and maybe the ST3 as the battery boxes are different due to the ECU location. There is a spare bolt hole in the battery box and just enough room for the regulator to sit securely on top on the battery while bolted in place. Not pretty, but it isn't going anywhere. Only possible concern is airflow, but it will get some through the faring and it is in no worse a place than the 916's regulator comes from the factory. Wiring is ugly. I decided not to cut the DC side of the harness in case I want to go back to the OEM location or somewhere else so there was a lot of extra harness to find a home for. AC side harness already had its plug cut for the normal reasons. I chose to not go directly to the battery on the DC side because I wanted to use the 40A fuse holder already in place and my bike's harness is fine. If I wind up relocating the VRR someplace like the tail section, I will probably go that route.
So, here it is, ugly as hell, but I'll give it a go.
The Shorai is a new addition, and that cool duct tape is just an effort to keep water off the cheesy dedicated charger plug I permanently installed because the ST fairings suck to remove should I need to have it on the maintenance charger. I don't ride the ST much, and there is a parasitic draw from the clock and possible the immobilizer. I am still uncertain how that will work out with the Shorai.
