1 - 10 of 10 Posts
Hey, thanks a lot for the responses, I will go for the one at Desmotimes, it is inexpensive and simple.......
I hear airplanes
I bought the one from DT.
Maybe I missed something, or am retarded, but it didn't "fit" without being modded a bit.
The holes for the rear mounting are spaced correctly, but if you place the bracket that far back, the center portion of it hits a portion of the undertail mud-guard.
The holes are too far apart for the second set of mounting holes.
I re-drilled the mounting holes (4) so that the bracket would fit all 4 stock mounting holes, and the singe center mounting hole as well.
It works, looks good, and was somewhat cheap ($25?...put it's plastic, so it's no huge bargin). But I did have to mod mine to make it work as I thought it should.
Get the short stalks while you are there. $5 for the pair, that is a deal.
Hmmm, mine mounted straight up. Completely plug and play. Hmmm.... Don't know what's going on. Got mine a couple of years ago. :think:
Mr Leakered
You can use just the two holes provided to mount it up. It is hard to say if two are good enough to risk loosing the plate. I did what TAftonomos did and drilled a couple extra holes for my own peace of mind.
The DT part works quite slick as I only have it mounted in the summer and throw the Duc fender on for wet weather to keep as much crud as possible off my top case.
Have good one.
I had the same problem with mine - but took 5mins to fix and works a treat
I had to mod mine too - didn't take long though, just had to reshape the frontmost part of the mounting bracket with a disc cutter.
These eliminators (DesmoTimes) are also for the earlier carby 900ss bikes.
1 - 10 of 10 Posts
