I was "playing" with the ST4S, under the tank, had the filter out, velocity stacks removed (they are pretty, huh?), the two rear mounting posts removed, but I could not find a way to get the front mount released !!!
Note that I was messing around in there with all the body panels on...does any ST4S owner know if the sides have to come off to do some magic to the front mounting post? I think there's a post up there--there's a similar lump inside the box's base, similar to the lumps where the 2 rear posts bolt into (I assume there's a threaded metal insert inside these lumps).
