My 2000 ST4. The tacho shows about OK at idle, but rev the motor to about 4000 and the tacho shows about 10,000. Rev it higher and the tacho goes right off the clock to about 3 o'clock. It's not a damping issue as the needle "holds" position until revs are decreased.
The tacho is fed from the ECU??? Either the ECU output is wrong, or some automotive instrument clusters have an internal voltage regulator (9V) that if they fail and supply alternator voltage (13.4) then instruments will "over read". Come to think of it, the fuel guage is showing about 2/3 when there is little fuel in the tank.
Is there a regulator in the instrument cluster??
Has anyone had any experience with this issue?
Regards, Greg
Regards, Greg
