Yes. There are some mod bits that you can buy. I believe desmotimes.com has one. Some folks have found that these can lead to running issues.
If you feel like taking on a bit of personal responsibility, you could just remove the slide stand switch and short the connector. The motor will start no matter what position the side stand is in and if you are in gear or not.
I've been running this way for quite a while without issue.
Have a good one.
Have a good one.
