There was a recent thread on this so you should do a search for it to avoid duplication.what's the best mounting option? any help will be appreciated. thx,
Do you have a picture of your setup posted somewhere? If not, could you do that? Would love to see where and how this looks...There is also this little puppy:
http://www.amazon.com/gp/product/B005J43I56?psc=1&redirect=true&ref_=oh_aui_search_detailpage
The threads work with my Cycle Cat bars. Check that they are the same for the ST3 bars.
Have a good one.
Thanks... So the M8 screw screws into an MSR expander that is fit into the inner end of the bar tube?Here's a pic of the phone mounted:
http://www.ducati.ms/forums/40-spor...quest-your-gps-mounts-setups.html#post4501034
The RAM base uses the same hole on the left side that the brake reservoir is fastened to on the right.
I don't have one of just the base or the mount. I can snag that tonight.
I did end up going with the 6in arm as the phone would bump the fairing if not installed just so.
Have a good one.
