Yes.stryder said:Thanks Mike.
I thought that PCIIIs, Techlusions "piggy-back" computers, took over the EFI functions from the factory ecu, and could be "mapped"
Also for the 5.9. The 5.9 cannot be remapped itself (which is what Mike was refering to, but explained badly), but of course the piggy-back computers don't care what you have OEM.stryder said:but not so for the 5.9?"
The Moto-one article used a Ducati Performance ECU with little improvement. No disrespect to the Moto-one tuner but I suspect he didn't take enough time to sort it out and figure why he wasn't getting significant improvement. My guess is there was something on that bike that didn't match the breathing characteristics that were intended when Ducati mapped the ST3 Performance ECU. This seems more likely to me than the possibility that Ducati screwed the map up so badly there was hardly any improvement but, of course, anything's possible. In time, more tuners will experiment with the ST3 and the Performance ECU and then it will become more clear whether the Performance ECU is poorly mapped or whether the Moto-one test bike was different in some way. It's possible that the breathing characteristics of the ST3 engine are such that there isn't a lot of room for improvement simply by bolting on pipe and airbox mods and using a different map. I suspect the truth lies somewhere in the middle. Time will tell.stryder said:Raising the fuel trim is what's referred to in the famous Moto-one article, so I'm guessing that's what the 1st tuner had in mind(?). (I mean the bike runs so very well in standard form, I just want some more grunt and a sweeter exhaust note)
I got the SILs for my SS from Carpimoto,stryder said:FWIW, the response I received from DJ re PCIII for ST3:
"Unfortunately we have not looked at this bike for development. We have been told by other Ducat dealers that part #710-411 will run on this bike but I can not confirm this. You may want to contact Fast By Ducat as they do quite a bit of Power Commander testing. Thanks."
Either they haven't heard the 3v is the only ST engine available commencing 2006, and rumoured to replace the DS1000 re emissions, or they don't see it as a big enough market, or they figure the #710-411 will do, which is listed for the S4 and S4R 2002-'05 Monsters. (916 & 996 4v?)
Also, my dealer called me back and stated I can get the Termi/DP kit with the ecu and air filter, for 50.00 less than a set of SIL Motor c/f ovals. Does this seem right? ie Termi/DP kit 1250.00 cdn, ie approx 1K used, and SIL slip ons, 1300.00 coden approx 1040.000 used. Those figures are plus applicable sales taxes, ie another 15%(cdn lol!)
EUR 500 is $690 cdn (not $750), according to my bank's website http://quotes.ubs.com/quotes/X0=30/X1=sHoMtfl7vcXLuU5$hJJAwsyeWOyeu1W6HtdRCTq4c79gLbzs7HMXOSSGtVQDZ1FCYpKd57z5nbwSt9psJSXvfkzLj$rMBJHt1nWFd1S7ZrSw=/X2=saxrvbkFvDdq4CtOVHbHntak9133$goIg (look at CAD - EUR rate)stryder said:750.00 cdn with 15% taxes is about 860.00 cdn, before shipping it with insurance AND then adding import duties at the border. Yes that should be less than 635.00, but how much less?
It'd be interesting to see your final costs for an apples to apples before I order anything. When are you getting them?
the alleged dp ecu i used was supplied by the importer to try to pinpoint an issue i was having with our demo bike where the immobilisor seemed to be activated by running the bike on the dyno and then turning it on and off with the rear wheel spinning, stuff like that. i figured it was either wrongly labelled or something - i've ridden st3 with dp ecu since that have been fine. so i assume it was a one off issue.Mike said:No disrespect to the Moto-one tuner but I suspect he didn't take enough time to sort it out and figure why he wasn't getting significant improvement. My guess is there was something on that bike that didn't match the breathing characteristics that were intended when Ducati mapped the ST3 Performance ECU.
any word on how the heads worked?st2lemans said:MBP, near Montreal.
Tom
My 944 ST2 has 90 RWHP, vs. my SS1000DS with open intake and Sils (same dyno, same day) measured at 87 RWHP.bradblack said:any word on how the heads worked?
