My 2004 ST3 is still burning out taillights. I asked this of the forum about six months ago and was steered to a few things to check but everything checks out fine. Proper voltage from the regulator. Engine RPM is kept 5K +. All the grounds in the circuit seem fine. I have replaced the taillight assembly and harness to no avail. The taillight lasts a few hours then the next time I check it prior to a ride it is out. I am trying to find a way to install the Zeus fastener to the taillight lens because I have to remove it so often. I have bought a case of the 2357 bulbs and always have a few under the seat and a screwdriver in my pocket.
I am asking again because maybe a few different persons are passing through this forum that were not here a few months ago that have heard of this happening to other ST3s and know the fix. I am more than willing to replace the VR if necessary but prefer not to if it is not the problem. I had the motorcycle out one day last week and had to change the 2357 bulb prior to departure and just checked it and found it to be good. I know though that the life of the bulb is 2 - 3 trips then it burns out (taillight only... brake filament is OK).
I am beginning to think this is the reason that the guy had it for sale (I bought it used last September).
It is not much of a problem as I just keep my topcase on which has the tail and brake lighting kit installed. My dealer is stumped and Ducati hasn't heard of this as a widespread problem that they know anything about.
Thanks all.
Thanks all.
