1 - 6 of 6 Posts
I got the "wrench" on my display at about 6,200 miles. I thought the first valve check on the ST3 is at 10,000 miles. What service is required at 6,000 miles, belts, fluids ....?
TIA
Jack not to tell what to do but if the belts haven't been changed do so soon. Your belts are past do. I had mine changed last year at 3200 miles at 2 years and they were starting to wear. Just adding my 2 cents.
Thanks, I did the belts last winter. They looked great, but then they only had 1,900 miles on them. I don't know why, but I thought the ST3 & ST3s had extended valve check intervals from 6,00 miles to 10,000 miles. Ah well, wishfull thinking and a senior moment .....
I believe it changed in 2007
I believe that starting with the 2007 model it went to 7500 miles for the value adjustment and remained at 12,000/24 months for the belts.
1 - 6 of 6 Posts
