1 - 2 of 2 Posts
Is this the one that's beneath the 14 mm allen fitting, or is it inside the area where the 14 mm allen threads occupy? If it's inside, how do I get it out, because when I removed the 14 mm allen fitting, that's all that came off.
Help!
Thanks, Jack.
When I did the filter last week, the outer 14mm allen came off fairly easily and then recessed inside was another 14mm allen attached to the secondary screen filter. I just put the 14mm allen in there and undid it. It was a bit tighter and I did go back to the manual to confirm I was on the right track. Sure enough put a longer handle on it and to popped free. You would not want to strip that inner 14mm as you would never get it out!
Vince
1 - 2 of 2 Posts
