1 - 7 of 7 Posts
Hey, I want to remove the stock plate turn and rear signal holder and replace with something much smaller. I'm happy to fabricate my own part and would be happy to see what others have come up with and-or something that can be purchased. I'm guessing there are already threads for this but since I'm new here, I don't fully understand how to find those threads...Craig
There used to be a company out of Vegas that made the best fender eliminator for these bikes. I believe they are long gone but if you want to search for "Delta V" for any of the fuel injected supersports it should be the same. I thought I had one around here some where if you are interested I will search to see if my memory is right, Pm me and be patient it might take a while.
I have seen home made eliminators ranging from great to terrible. Most are simple bent sheet metal affairs that get the job done and look decent enough. If you are handy I would expect you can fabricate something without a welder being involved. Pay attention to plate location and turn signal mounts as these are often the places people go wrong. Plate angle needs to not hit your rear tire at full suspension compression, you have no idea how many get this wrong and find out only when the plate is smashed into their tire.
I just bent some aluminum to bolt up to existing holes, plate is all that shows so workmanship isn’t a big deal. Bent the correct angle to keep the plate off the tire after install.
Discussion Starter · #6 ·
New tail from no dumping sign
Made this today from a "No Dumping" sign I had. Going to coat it with satin epoxy paint. Im using the stock turns and the stock license plate light. Thanks again for recommendations.
1 - 7 of 7 Posts
