My other bikes are shaft drive. I didn't realize you could customize things by switching out the front and rear sprockets. Cheap and not hard to do. Lots of information on this site about which ones to use. Very helpful. this is for a 97 900SS/CR.
The factory stock is 15 teeth front and 37 teeth rear. The PO had it set up really "sporty". 14 front and 41 rear! On the windy country roads I ride on, it was definitely athletic. Super responsive in the 4000 to 6000+ range. But, riding on the highway at 70-75 mph in top gear was pretty buzzy. I increased the front to 15, and reduced the rear to 40. Got a kit from Renthal. About $100 if I recall. Better now. A little compromise on each end. Before in 6th, 60 mph was about 4000 rpms, now at 4000 rpms around 70 mph.
There is a website Gearing Commander which was helpful. Just plug in the information on your bike, and it gives you rpms and speed in various gears. Put in different sprockets and it gives different figures. Very helpful in picking what you want.
