Back in stock - Adjustable angle clip-on bars for more comfort. Fits most 22mm or 7/8" clip-on mounts.
SPEEDYMOTO OMNI Replacement Angled Bars
$69.95 / Pair
SpeedyMoto hasn't re-invented the wheel with its new adjustable Omni Bars but we have come up with a more refined and simply more functional way to make your bike comfortable.
Omni Bars give you all of the adjustment you will ever need for perfect ergonomics.
You can use Omni Bars with your stock clip-ons (22mm diameter) or upgrade to SpeedyMoto clip-ons.
Use the built in alignment marks for a perfect setup every time.
Rotate the unique 14 degree Omni Bars to adjust the height, drop, sweep and pullback.
The Omni Bars maximum adjustment is over 4 inches at the bars end.
20% stronger than standard clip-on bars.
NO PROPRIETARY BAR MOUNTING DESIGN! So less weight and much easier to adjust.
All SpeedyMoto adjustable Omni Bars come with bar end sliders and are available in black only.
NOTE: These will not fit on OEM Ducati and MV Agusta clip-ons with offset pins to mount the bar. These complete adjustable clip-ons are available with a 20mm rise if you have that set-up:
SPEEDYMOTO Adjustable Clip-ons: 50mm
SPEEDYMOTO Adjustable Clip-ons: 53mm
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for the deepest discounts on all items. Look for memberships on the Motowheels website and choose the membership type that fits you the best
