Save some money by ordering it all at once: Kit includes front axle, rear axle, and the frame sliders.
SPEEDYMOTO Complete Slider Kit: Ducati 696, MTS 620 And [Only With High Mount Exhausts: M620ie/695ie/750ie/800ie/900ie/1000ie/S4]
Pricing: $274.95 FREE Shipping
The SpeedyMoto complete Front/Rear axle and frame slider kit with the long sliders for more protection.
SPEEDYMOTO Complete Slider Kit: [Short Frame Sliders] Ducati 696, MTS 620 And [Only With High Mount Exhausts: M620ie/695ie/750ie/800ie/900ie/1000ie/S4]
The SpeedyMoto complete Front/Rear axle and frame slider kit with short low profile sliders.
The frame slider includes extremely durable 17-4 stainless steel engine studs. Precision-ground, thread-formed, quenched and tempered to an aircraft grade tensile strength of 185,000 psi, our stud far surpasses OEM specs (as well as other manufactures) in both strength and wear-ability.
The SpeedyMoto Ducati Front Axle Slider Kit is the strongest system available on the market.
The kit is comprised of superior HDPE plastic sliders that offer crash resilience and protection.
Exceptionally strong anodized aluminum support rod, that is corrosion resistant.
Kit includes stainless hardware that is also corrosion resistant.
SpeedyMoto rear sliders are made from superior and more expensive HDPE plastic, which slides and absorbs impacts better than any other product on the market. Other materials tend to grip, flip and brake.
Works with a standard rear stand so you can service the bike easily.
Easy installation, only takes minutes.
Anodized aluminum rod and stainless hardware holds both side firmly together and won't corrode!
We employ stainless steel for the integral engine nuts and slider support, not unlike the high-strength engine bolts used by Ducati race teams. Corrosion resistant and strain-hardened stainless steel is ideal for the crucial applications of holding your motor in, supporting the entire chassis, and providing a reliable platform for the actual slider.
SpeedyMoto uses Ultra High Molecular Weight (UHMW) plastic for the slider puck. Unlike other plastics, the unbelievably low friction coefficient of this plastic makes it practically glide on the pavement. By using this material the risk of 'grabbing' is reduced, avoiding turning a smooth low side into the dreaded catastrophic high side.
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to lifetime VIP passwords for the deepest discounts on ALL products.
Look for memberships and choose the membership type that fits you the best
* Outside continental USA, use shipping codes:
