I did google that's how I came up with there being an Iridium option. SorryUse the search function, or google it. Anyways, here is what I found and I just so happened to order 4 of those last night on the motorcycle superstore link. The NGK Canadian link in the discussion below don't sell them for whatever reason, so you have to find a different vender.
http://www.ducati.ms/forums/92-hypermotard/98891-iridium-plugs-anyone.html
http://www.ducati.ms/forums/80-hall-wisdom/70575-platinum-iridium-sparkplugs.html#post670501
NGK DCPR8EIX - Iridium Spark Plug - Cruiser Motorcycle - Motorcycle Superstore
It was just a curiosity thing really....I know plugs don't really come into play much until you get into high hp applications where gap has to be spot on and you need a pretty cold plug. Spart plugs for my truch were $12 each so $96 for plugs once a yearRegular version is dirt cheap, $3,50 a pop I believe, which is the cheapest I've ever seen for a spark plug. For those prices I wouldn't consider iridium. Iridium plugs are made to last long, they will however cost substantially more. If it's performance you're after, then it won't gain you anything.
796 has only 2. 1100 has 4, 2 of which are on the belt sideGot my 4 spark plugs in from motorcycle-superstore. I've been searching, but couldn't find any how-to switch spark plugs on a hypermotard. I saw the 2 spark plugs on the right hand side which are simple to get to, but there are 2 more correct ? If anyone can shoot me some good info on swapping out the spark plugs it'd be much appreciated.
Gracias and enjoy your Cinco De Mayo, I'm holding off on my maintenance until next Saturday and am going to start on margaritas, cervezas, and beach.
Where?Regular version is dirt cheap, $3,50 a pop I believe
only pre-evo model has 4 plugs. The evo models only need 2.from what i discovered the older hypers had 4 plugs.. i couldn't find 4 plugs on the bike itself nor on the interwebz for the later model bikes
x2Save your money. Replace your plugs every year with plain ole ngk's. You'll know the plug gap is consistent.
