The trick is to treat them with silicone grease before you put them in the hole and twist them while prying them out. Try to get them moving in any direction and break them loose before tugging hard.
Thank you! Will give that a try. I was wondering about using a dialectic grease before putting the new wires on.The trick is to treat them with silicone grease before you put them in the hole and twist them while prying them out. Try to get them moving in any direction and break them loose before tugging hard.
