1 - 15 of 15 Posts
Probably a non-starter, but figured I'd ask. Any alternative for this part (46320537A)?
It's the o-ring that sits behind the front sprocket. Supposed to be replaced with the sprocket.
TIA
Changed plenty of front sprockets and never noticed a o ring, ever.
I should pay more attention i guess
Sophomore Member
I just changed chain and sprockets on my multi and didn’t notice it. 🤷
I can’t remember an o-ring when I did my 2010 MTS, but any time I need parts AMS Ducati always seems to get me what I need.
Pic below. It's behind the spacer that sits next to the sprocket. Manual says, "Must be renewed on assembly".
990768
AMS has a single for $1.25 + $9 ship. Omaha has a 5-pack for $6.25 + $9 ship. I was hoping there was an alternate (KTM, BMW, etc.) that I might be able to source locally. Shipping has been so slow lately and I'm in a rush.
Never saw an O-Ring on a BMW
... or you can get some here:
No affiliation just a satisfied customer over the years for small lots of many and varied o-rings. Good selection, prices and excellent service.
Discussion Starter #9
Cool resource.
I'd have no idea how to answer #2-#4 though under 'Required Information'. Seems fairly critical though:
  • O-Ring Size (inch or metric) - Cross Section ( thickness ) X Inside Diameter
  • Temperature Requirements
  • Compound or Material Being Sealed
  • Operating Pressure - Durometer Rating
  • And of Course Quantity Required (Non-Stock O-Rings may require a minimum)
Sorry - should have been more specific ... this will work fine:
Metric
1.78mm thickness
25.12mm diameter
Buna-N 70 Durometer (will be fine for this application)
Minimum order is 20 but at a nickel a piece you can use one and throw the rest alway (compared to OEM prices).
I gotta ask. Why would you swap out the oring? What’s it sealing? Dust...unless you lose it, why bother? My guess is very very few people have ever changed that oring. Just trying out that common sense stuff.
Reactions: t-bills
snip picture
Renewed on engine assembly, not sprocket change
Discussion Starter #13 (Edited)
I can't really answer that. If Ducati recommends it, I can only assume they have a good(?) reason. Maybe the environment in which it lives dictates replacement once it's disturbed.
I'd guess nobody's bike has imploded for lack of replacing it. But if it's a recommended low cost item, easily replaced, etc. it will appease my OCD if nothing else.
Discussion Starter #14
As it's external to the engine, and under the "sprocket removal" section, can you expand on your logic as to why you would only replace it on assembly of the engine?
I've never even pulled that spacer off... guess I better take a look at it during the next sprocket change.
1 - 15 of 15 Posts
