Well my clutch is starting to rattle bad for a Ducati.........
I had a quick look with a torch and I have a fair amount of tang wear.
I have the Desmotimes book, A service manual now and the Haynes Guide.
There is some contradictions, I hope you guys could clear up.
The service manual at first read doesn't say if its good or bad to pull out the push rod from the slave to the pressure plate, as i understand the desmotimes one its recommended to avoid total removal. an the haynes also seams vague.
How hard is it really to do, a plate swap? and if needed a basket swap?
Also how easy should it be to remove the rod from the pressure plate bearing?
ta...
ta...
