He, he, he:}Best to just keep the throttle wide open, no problems with that.
1) check your chain tension. That was 90% of the problem on my bike.Hi-
What are folks doing to help smooth out the snatchy throttle response?
I installed a G2 throttle tamer, but it doesn't seem to have helped...
Your advise and experience is much appreciated
thanks
Fatduc solved the problem for me.Hi-
thanks
I just checked my chain tension and it was at 34mm.1) check your chain tension. That was 90% of the problem on my bike.
1. I have the G2 throttle tamer, is the Kyle better for the Hyper?kyle throttle tube..worked for me
Also a less expensive solution...Have you checked and adjusted play in the throttle cables ?![]()
