Generally, I am pleased with the ride and handling (especially compared to the Multi 620 I had before!), but I had a few small issues. While the suspension is very "plush" compared to the 620, the more I rode, the more I was getting annoyed by small road imperfections. These imperfections also seemed to make the Hyper "wiggle" over bumps a bit more than I liked, especially on corners where the rear would "hop" over small bumps. Rear tire grip also seemed a little slippery when leaned over... (BT-14S)
1st, I hadn't checked the tire pressure since picking up the bike. (I know, I know...) My dealer had set it to about 33f/36r so I lowered them to 32/33 (cold).
2nd, the suspension was at factory settings (15 clicks rear, 1 1/2 turns front). I went 3 more clicks out on the rear, and another 1/4 turn out on the forks.
3rd, I increased the rear preload by 1 turn. BTW, how do you guys adjust rear preload? (non-S) There's NO room for a tool, and using a hammer and screwdriver - even with the tip covered in duct tape - made notches in the soft adjuster rings! Arghhh...
So NOW the Hyper is mush smoother over small imperfections, the rear grips WAY better, and the overall ride is plush, but not mushy. Amazing what a few tiny tweaks can do. I'm much happier!
