Worth every penny. Down shifting is like butter and the clutch pull is effortless.Surflex sells a Streetfighter slipper that allows you to use your original aluminum clutch basket.
SURFLEX Slipper Clutch w/ Plates: 1098,1198,SF
It comes with the new Surflex friction plates, springs, throw out bearings all ready to install for only $999.
-M
If you use a Surflex with an Oberon slave cyinder it feels lighter than a cable clutch.The slipper reduces clutch lever effort? How much?
I will admit, that even with a clutch slave, the DP slipper lets you feel a "twang" on some lever pulls.Few notes; The Surflex does not kick back to the lever on downshifts, no ball bearings to lube, its lighter, makes less noise, uses the OEM basket (saves money for other mods) and again, the clutch pull is smooth and greatly reduced.
