Running a 2014 Pikes Peak. Trying to set Sag. I've read about every thread for the last 2 days about setting it. However, there's no clear method on measuring. I'm seeing consistently 55mm of Sag based on 170mm or travel. Do I need to get this from full extension of the front forks, measured against the value with the rider in seated position?
Most my other bikes I'm setting Sag based on the bike sitting on the ground, and the forks NOT fully extended. Usually 6-10mm for track duty.
There's so many variations to the bikes, Ohlins vs electronic, etc. Just trying to get my Skyhook dialed in. I found this recommendation:
Divide your weight by 15kg, and wind in from fully anti clockwise that number multiplied 360 degrees.
Not teaching you to suck eggs, but example, 90kgs in clothes and boots etc. So 90kg divide 15kg is 6. So 6 full 360 degree turns in from fully out.
