Has anybody fitted the DP skid plate on a HM with the 2/1 Termi exhaust?
Looking at mine, there is no room to fit the rear/right bracket between the engine and the pipe.
Well like I said earlier there was just not enough room for the bracket to fit so the exhaust had to come off and the exhaust had to be shimmed at the mount point to give the bracket enough space to fit between the engine case and the exhaust.
Hey I take offense to that (not really ) both my parents where born in Sicily and I'm a mechanical engineer...
I checked again my header is up against the footpeg bracket and there is maybe 5 mm clearance to slip the slid plate bracket. DP engineering want to feel like you're part of the engineering team so they make it that you've got to go the extra distance to make everything fit.
