I've upgraded from a 996 to an 1198S... I liked the 996 because the ecu wasn't very smart and simple to manually set the TPS, then sync the TB's, etc, etc,
Can someone recommend a software to get (and necessary cables) that is relatively painless to use to set the TPS. Or tell me where to find directions on how to do it manually (volt meter on ecu pins).
My goal is to :
1. check tps
2. sync TB's
3. set CO levels
Thanks in advance...
My goal is to :
1. check tps
2. sync TB's
3. set CO levels
