1 - 2 of 2 Posts
Can anyone help? I have a 2007 S2R 800 with stock Marzocchi forks; can the adjustable Showa forks be used to replace them? If so, what does this entail?
radial or 65 mm caliper spacing then staction diameters some models will be interchangable like the sport classics we to suffered with bad stock suspension but with time u can actually dial in those junky marz to be quite effective . stock is under spronge and damping is suspect but with good springs and playing with oil vicosity they actually work. sometimes upon delivery some fork s had too much oil or not enough .and the springs for 120 lb riders
1 - 2 of 2 Posts
