1 - 10 of 10 Posts
Had my fork seals replaced, they were leaking. When I got my bike one of the the preload adjusters sets higher than the other. Both are adjusted per the manual (2 1/2 turns). They were both even when I had the work done. Thanks guys.
Discussion Starter · #2 ·
well, I guess that after over 100 of you guys checked out this post there's nothing to be concerned about.
Retired Pipe Polisher C2H6O+
The guy that put the fork caps back on didn’t do it properly. If not done properly you may not have the full range of adjustments available.
Hammer Down
2020 Multistrada 1260 S Touring
Nah, it just means you had an interesting, nondescript, title and 100 (now 101 since I looked I guess) people didn’t know how to answer your question.
It is your rebound adjusters that don't match. Back them all the way out and (record the clicks) then screw them all the way in (don't force them tight) record the clicks. Are both side the same, did this fix or identify your problem?
t_bare
Discussion Starter · #9 ·
They both have the same range of preload adjustment but I am going to take it back and have them explain it to me. Thank you all for your help.
1 - 10 of 10 Posts
