Will short lever affect leverage, as far as how hard they are to pull in?![]()
Brake lever options for the Hyper
Take a look at this 950 ducati built...you might like the hand guards too. https://www.ducati.com/ww/en/news/ducati-villa-este-hypermotard-950-conceptwww.ducati.ms
Thank you. Do you have a link where I can get them? The sites I have looked at say that they are not compatible with the 2020 hyper.The short levers are typically the same geometry as the long levers, they are simply shorter and cater to the one or two finger brake applicator. If you want to start experimenting with lever geometry, the brembo corsa corta allows for variations.
It still doesn't say anything about it fitting the hyper 2020. Last time I ordered something that was not specific for the bike, I had to return it. I don't want to make modification, just switch it out.Here you go:
Anybody have a favorite adjustable brake lever to recommend? I brake with two fingers, index and middle. I find the stock lever lacking in adjustability to suit my taste. I think an adjustable shorty lever would do the trick. Recommendations?www.ducati.ms
