Shorai Lithium Iron LiFePO4 Battery Kit: Ducati 1199/1299 Panigale
Price: $209.95
Sale: $189.95 FREE Shipping
18 Amp Hour, 270 Cold Cranking Amps.
Ultra-light weight - 2.3 lb.
Ultra-compact - 5.83” x 4.13” x 2.60”
Includes longer negative cable, bracket for Panigale fuse box cover and zip ties to secure battery.
Weight savings over stock battery is 3.3 lbs and increases cranking power significantly.
Ultra- low self-discharge rate and no sulfating (i.e. does not degrade while sitting unattended).
Twice to four times the service life of lead-acid batteries.
Drop-in replacement for your OEM battery.
Super-fast recharge rate.
SAFE - No explosive gasses during charge, no lead, no acid.
Environmentally friendly, just discharge and dispose.
Japanese engineering and components.
Shorai has created a battery are like no other with prismatic cells, delivering more energy faster, with less weight and with less damage to the battery per start cycle than any other brand or technology.
Shorai Lithium Iron prismatic cells (chemistry LiFePO4) reduce the battery size and weight compared to conventional lead acid batteries.
Shorai LFX batteries have been designed from the “ground up" to be a powersports starter battery with long lifespan and high performance, under a wide range of temperatures.
Limited Two-Year Warranty.
Installation requires using the included longer negative cable and raising the positive cable due to the Shorai battery being slightly taller. Also the OEM top battery bracket will not work and so we include a zip tie to secure the battery to the tray. Since the top bracket is also used to secure the plastic fuse box cover we also include hardware to reuse the bracket but only for the purpose of attaching the fuse box cover.
Shorai Dedicated Battery Management System
Price: $79.95
Sale: $71.95
A complete management system that incorporates modes for full charge, or long-term storage.
· Full Charge Mode charges, balances and performs cell diagnostics.
· Store Mode maintains maximum battery life during long term storage.
· 2A Max charge rate, connects via BMS 5-pin port on LFX batteries.
· Input 100V/240V AC, 50/60 Hz. This model includes AC adapter cable for USA 110~120V only.
· Can be used with international convertor / adaptor plug for 220V/240V. NOT INCLUDED.
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or VIP passwords for the deepest discounts on all items. Look for memberships and choose the membership type that fits you the best
