My saga continues with the engine stumbling. I thought I had it fixed with putting the old plugs back in but when I got everything back together it returned. The common factor with good and bad performance is the tank up and down respectively. I reached for the key and touched the bracket bolted to the front of the tank. ZAP!
The only thing that could cause that is the ignition wire shorting to the tank.
These are about 5 month old Magnecors. I even have plastic wire harness wrap where it goes over the head.
That would explain the engine missing. I bought this bike used Is there supposed to be something to protect the wires? There isn't much room under there at all. I'm going to put the stock wires back on, these must be faulty!
