1 - 2 of 2 Posts
just picked up an ohlins to swap out my sachs. searched but found no answer. i can't seem to get the lower shock mount bolt out. i removed the rubber swingarm plug and loosened the bolt inside the hole and the bolt won't come out and the ride height ball joint is spinning. Do i need to remove the plug on the other side--that is, remove that chunk of exhaust pipe and poke it through or something?
any help would be appreciated. thanks
Make sure you get the weight of the swingarm off of the bolt, and use an automotive magnet on a stick to get the bolt out if you can't extract it with the allen wrench.
1 - 2 of 2 Posts
