1 - 13 of 13 Posts
We have sold our Shift-Tech Project bike in stock condition and are now selling the parts that were on it.
Custom build Shift-Tech Titanium Full System with Carbon Fiber muffler. This full system eliminated the cat and your exhaust valve. You will need to install an exhaust valve eliminator devices, many sold on Ebay, otherwise you have a check engine light since you don't the valve any more.
Muffler mounts to the back of your OEM rear passenger pegs and comes with all mounting hardware needed.
Takes OEM heat guard, pictured carbon fiber heat guards are not included in the listing, they are available for purchase.
These are no longer made by us so here is your chance to get the last one.
2000 mls of use on it
This item is in very good condition with no damages. $ 1399.00 - no member discount can be applied.
Discussion Starter #2
Shift-tech carbon fiber monster 1200/821 carbon fiber heat guard set
100 % Real Carbon Fiber Gloss inner and outside heat guard, direct replacement for OEM version.
2000 mls of use on it.
This item is in very good condition with no damages. Fit's M1200/1200S/821 $ 245.00
SHIFT-TECH MONSTER 1200/821 CARBON FIBER R&l ENGINE PANELS
100 % Real Carbon Fiber Gloss upper & lower left engine covers, replaces OEM verison.
This item is in very good condition with no damages. Fit's 1200/1200s/821 $ 245.00
Shift-tech monster 1200/1200s carbon fiber belt cover set
100 % Real Carbon Fiber Gloss full belt cover set, direct replacement for OEM plastic belt covers.
Retail price $ 339.00
This item is in very good condition with no damages. Fit's M1200/1200S -- $ 245.00
Shift-tech carbon fiber front fender monster 1200/1200s/821
100 % Real Carbon Fiber Gloss front fender incl. clip for the front brake line, direct replacement for OEM version.
This item is in very good condition with no damages. $ 155.00
Shift-tech carbon fiber key guard monster 1200/1200s/821
KEY GUARD/IGNITION COVER GLOSS MONSTER 1200/1200S/821 All Years - Used but in very good condition, no issues with it at all.
Retail Price New $ 179.99
Material: 100% Carbon Fiber
- Direct Replacement For OEM Part ----------------- $ 125.00
Discussion Starter #7
Shift-tech carbon fiber subframe covers monster 1200/1200s
ST1077 FRAME COVER SET MONSTER 1200/1200S --- GLOSS --
Used but in very good condition with no issues -
Retail $ 205.00
- All Years/Models 1200/1200S
- Superior Fit & Finish
- Produced in state of the art Autoclave manufacturing process
- Finished with automotive finish clear coat with long lasting UV protection.
- Pre-preg Carbon 200g Plain Weave ( same structure and finish as Ducati Performance Parts)
Material: 100% Carbon Fiber ------------ $ 125.00
Discussion Starter #8
Shift-tech carbon fiber monster 1200/1200s/821 coolant tank cover
100 % Real Carbon Fiber Gloss right coolant tank , replaces OEM verison.
This item is in very good condition with no damages. $ 125.00
Discussion Starter #9
Shift-tech carbon fiber monster 1200/1200s undertray $ 95.00
ST1074 UNDERTRAY MONSTER 1200/1200s - GLOSS FINISH
- USED with small scuffs in clear coat from normal use, as pictured some holes were drilled into the undertray where a custom license plate holder was bolted onto, no plate holder included.
Retail Price New $ 249.00
- Due to the design of this item the Seat must be in the UP position with this product.
- Direct Replacement For OEM Part --- $ 95.00
Discussion Starter #10
Shift-tech carbon fiber hugger rear fender monster 1200s 1200 $ 85.00
100 % Real Carbon Fiber Gloss rear fender, direct replacement for OEM version.
Please note that on the 1200 base model with Sachs shock this hugger will fit also but you will see the depression in the hugger for the shock section of the Ohlins.
The left main mounting bolt has been enlarged and you will need to use a bolt with a large head to fix it to the swingarm ( bolt not included) or use a washer under bolt head and on underside of hugger, also there is a scuff mark on the section where the shock sits near the hugger.
$ 85.00
Discussion Starter #11
Shift-tech carbon fiber fuse box cover monster 1200 1200s $ 69.00
100 % Real Carbon Fiber Gloss fuse box cover that is located on the swingarm, direct replacement for OEM version.
Discussion Starter #12
Shift-tech carbon fiber sprocket cover monster 1200/1200s/821 $ 50.00
100 % Real Carbon Fiber Gloss front sprocket cover, replaces OEM verison.
Discussion Starter #13
Monster 1200/1200s ohlins rear shock $ 450.00
Used OEM Ohlins rear shock with OEM spring just powder coated black. For Monster 1200/1200S all years.
Shock has no issues and is clean.
1 - 13 of 13 Posts
