1 - 2 of 2 Posts
In the process of replacing the transmission on a 749 and need some advise setting up the gear selector lever and the shift drum. If it wasn't such a pain in the ash pulling the generator cover I'd give it another go. The first attempt wouldn't down shift with the clutch, worked fine up shifting. Second attempt would not allow for a solid downshift from 2nd to 1st unless at higher speeds, but shifted up and down thru the rest of the gears with no issues. Question; Is the drum tool a necessity? Any advise appreciated.
Drum tool #88713.1091
1 - 2 of 2 Posts
