Just finished installing a Shindengen SH847 rectifier on my Hypermotard. The install was better than I had hoped. Since I am using a lithium battery, I am hoping this mod will help my batteries last longer. The SH847 is considerably larger than the stock unit, so mounting it was a concern. My bike has the CA Cycleworks oversize tank, so excess space is limited. After some ideas of creating brackets to mount the rectifier due to the mounting holes are spaced out differently than the oem rectifier, I noticed 2 unused tabs on the frame under the left shroud. The holes matched the SH847 perfectly. I thought this was too easy and perfect. After a mock up, the only thing that needed trimming was the removable black plastic inner shroud. I decided to replace one of the harness plug connectors (the one that goes to the stator) and install a much improved water resistant plug. The other connector on the harness was capped and I wired the rectifier directly to the battery.
P
