gday guys,
ive recently done a stock can mod. and for those who are wondering, it is FREAKEN loud. the work carried out was a total gutting and welding in the 'straight through' perforated tube, same specs as a Termi system. while i had the bits apart i ceramic coated the outside tubign to resemble a Streetfighter S system. i personally love it, it sounds fantastic at idle, a little louder and higher pitch than a termi. the lower to mid sound is a little bit on the raspy, but top end sounds great! i can recommend the mod to anyone who wants to do something a little bit different than goin the usual termi way. i decided on this option as im a big fan of the stock look, and so far ive yet to be swayed by the termi cans as they look a bit smaller and sleeker, which i think goes against the look of the fighter which is meant to be chunky and sorta industrial. (if that makes sense)
i may be imagingin things but i got the chief tech at the Ducati store to have a go, but it does feel a little nicer on the on/off, def not a cure, but def not worse which really confused me as i was expecting it to get worse. im currently waiting out on the TUNEBOY ecu program to be released which will cure our bottom end fueling woes, aswell as binning the exhaust flapper and O2 sensors. the TUNEBOY thingy should be out round end Nov / start Dec.
photos to come
