Good day guys, let me thank you for your help in previous topic (have helped me much).
But i found another ?problem?. To be honest i dont really know.
Somebody is telling me "its normal, its only leaking factory oil which was added at building motorcycle to this part"
Thats why i would be glad to hear your opinion.
I noticed that something like "oil" is leaking close screw. First time i noticed this leaking was after i changed compresion damping to harder (1/4 from fully closed instead of 1,5 turns). Maybe i just didnt noticed it before .. i dont know.
I completly cleaned whole screw area of compresion setting and after 60 miles of ride i checked it again, you can see result on attached screenshot. (there is visible leaking drop) :
Should i start to worry about my suspension? :(
Many thanks guys!
Your suspension components should not be leaking oil. If they are, you have a problem that needs to be corrected.
If you spot a weap and clean and it returns it's not right,wipe once more with a bit of cleaner but I bet it's a fault
