Is the clutch rod the same for the other Ducati's as the SF rod ? I noticed the diagram had a new part number 11721121A that has a pin at the end of it
2011 The diagram shows that there is a plastic spacer now and pin as well in the diagrams like the 2012SF. Trying to find a clutch rod to replace the 2012 SF part numbers match up
ok, just to follow up, to 2012 SF does use a different clutch rod. Purchased a replacement from dealer. Thought you guys should know. I ordered a extra one off of ebay to pull the pin in and see if the aftermarket clutch slaves will work
There's only one clutch slave, how many rods do you need?
If you explained what it is that you're doing step by step I'm sure you would find the answer here...
Related Threads
Ducati.ms - The Ultimate Ducati Forum
2.5M posts
93.7K members
Since 2005
